XY Graph 2 X-Axis diffrent scale
for mass spectra analysis i want a XY Graph with two x-axis. one for time (linear scale) and one for mass (quadratic scale).
As data input i will have two arrays, one for time, one for amplitude.
is there a way to get a second x-axis scale as a function of the first x-axis?
thanks in advance
maxmustermann12
(3,738 Views)
Hi Max,
set the scaling properties of your second X axis as needed - there are properties to select the axis and properties to change axis properties!
(3,727 Views)
i searched for such a property, but i found only offset and multiplier, but this results also in a linear scale
am i wrong?
(3,703 Views)
Hi Max,
sorry, I missed the "quadratic" part…
No, scales are only variable in a linear way.
For everything else you could draw your own scale(s) using 2DPictureIndicators!
Edit: You might support this LabVIEW Idea!
(3,698 Views)
