XY Graph Messing Up When Opening Other Applications
For some reason, whenever I open task manager or microsoft word, or any application, my XY Graph glitches momentarily. Does anyone know how to fix this?
Message 1 of 10
(4,176 Views)
Wow, this happens if i do print screen too.
Message 2 of 10
(4,166 Views)
What do you mean by "glitches"?
Message 3 of 10
(4,152 Views)
See attached.
Message 4 of 10
(4,149 Views)
Seems to me like you're trying to draw the graph using some sort of software timing, and when you launch Word or do something else then Windows decides to preempt your LabVIEW VI. Are you drawing the graph using some sort of software timing?
Message 5 of 10
(4,146 Views)
Yeah, its generated data, every 10 miliseconds. I'm using the wait until next milisecond multiple VI.
This is not happening with the NI generated sine wave, which uses the sample clock. Hmm...
The problem is that I'm going to be interacting with a galil card, and even though right now its generating data every 10 miliseconds, wen the card goes in, im going to be sending commands to get analog inputs every 10 seconds and the same problem is going to happen.
Message 6 of 10
(4,142 Views)
Unfortunately, this is going to be affected by you launching an app like Word.
Are you referring to one of the signal generation VIs? Those actually create a waveform datatype, which has a start time, deltaT and array of values. There's no "real" timing in the sense of a clock. Or, are you referring to something else?
What's a galil card?
Message 7 of 10
(4,128 Views)
Galil Motion Control card for controlling multiple axis servos.
No by NI data, I mean DAQ MX, but simulated channels.
For the Galil Card, I get analog input values by sending commands to the card. Maybe that one is not interfered with applications opening...
Message 8 of 10
(4,122 Views)
I wouldn't expect this to occur if you will be conducting hardware timed data acquisition.  When doing data generation is being done within software you are at the mercy of your processor which is distributing it's efforts to all the applications running on your computer.  But if your data is coming from another piece you are at the mercy of your Galil card, which does not have to worry about other applications opening.
I hope this helps.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 9 of 10
(4,103 Views)
If these blips are a show-stopper, brace yourself.
I avoid those issues by starting up a background process to do countinuouse double buffered acquisions so that hardware keeps collecting while Windows is off in la-la-land.
If your widget demands software intervention then you will have to move to a real-time platform, a different set of hardware, or maximize your screen and don't let anyone launch any other code while you test is running.
Ben
Message 10 of 10
(4,095 Views)
