XY Graph Multiplot Help
No problem, it'd be fine to have them in there then.
Cheers!
Marti C
NI Medical
Message 21 of 23
(1,149 Views)
We are working with the HP4195A network analyzer and are trying to display the readout information using a multiple x-y graph. We would like to display redaout from registers A and B (Y domain) in correlation with the readout from register X that contains frequency information (X domain). We succeeded in displaying A i B while the X domain was defined by sample number (from 0 to 400). We are not sure how to use the graph to show A i B in correlation with frequency that we are reading from the X register. Please see the 'NWAnalyzer Read Trace.vi' in the attachment.
Thank you.
Petra&Daria
Message 22 of 23
(1,044 Views)
Hi Petra and Daria,
From my understanding it sounds like you want to be able two display two plots (A and B; Y values) correlated to a X axis (frequency values). I looked at your attached .vi. It looks like you need to send your XY graph x values. Right now you are only sending your chart Y values for 2 plots and by default the chart is using 0,1,2...400 (sample number) for the X axis.
XY Graph.vi in the example finder should be of much assistance; this is for a graph but you should be able to convert these ideas to a chart (the difference between programing for charts and graphs is explained in this Knowledge Base). You need to Bundle your X values with both sets of your Y values, and cluster these together. I have downgraded the XY Graph.vi to LV 8.2 and attached it. Hope this helps.
Screenshot of XY Graph.vi
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
Message 23 of 23
(1,032 Views)
