XY Graph Properties Import
I am having problems exporting xy graph,  xy min and max properties into xy graph in my print vi. Probes indicate property values from the original graph are correct. Probes also indicate correct property values at property nodes of target graph. Target graph does not reflect property value changes. I'm missing something.
Code attached 7.0
Newbie DLD
(3,060 Views)
One of your sub VI's waveform chart print.vi, did not make it.
Pls post that vi.
Plus you seem to be printing front panel of that VI,
where are you setting properties of the graph that seems to be inside that sub Vi ?
(3,048 Views)
That's it. I was not setting the properties inside the subvi.
newbieDLD
(3,032 Views)
