XY Graph: Straight Vertical and Horizontal Lines
I need help figuring out how to add horizontal and vertical lines on my xy graphs. I have provided an example to let you know what type of graphs I am looking to recreate.
Please let me know if you have any ideas. I hope there's a simple solution that I've overlooked. But I have a feeling that's not the case.
Thanks for the help!
(4,742 Views)
You could add a few more plots, each containing two points defining each line, programmatically place cursors (potentially with labels shown), or even use the "plot images" feature, which allows you to draw anything using picture functions on any kind of graph (xy, waveform, intensity ...). It will also allow you to write the text portions.
(4,732 Views)
