04-11-2009 04:56 PM
DRAYTON wrote:I have used the program 'array.vi' as a subvi in my own program but it isn't working . someone know why it's not working?? I am getting nothing as graph? Please help me
thank you
You will need to provide more detail than that! How is it not working?
Is this the same VI that was posted in the message above? That VI has a while loop in it stopped by a Stop button. If you use that as a subVI, you need to eliminate the while loop.
04-11-2009 06:54 PM
yes but i thought if you eliminate the while loop in the program array.vi then will the sift registers also be removed . the program will not be work then.
Can you place the program 'array.vi ' in my own program 'eindwerk_data.vi ' so that usefull is . I have not so much experience with Labview. So can anyone makes that program einwerk_data usefull is. (I want to measure torque and power in function of rpm (rotate per minut) )
04-25-2012 04:46 AM
Dude are you sirous people are tryin to help you the give you a great piece of code and you asking them to put in in your VI. You can't ask people to write code for you so you don't have to do anything. Thanks a lot for the code, i'm working on a kindalike project, and also starting from no programming experience. It's a bit the same as math, once you seen it, it's logical.
01-21-2014 04:49 PM
8.2 Please
01-21-2014 04:53 PM
Joery
Can you post this in 8.2. Thanks ,...
