XY Graph Time As X axis Controlled By Property Node
I am building a vi in which I will be plotting data against the time.  I am using an xy graph along with the xy  chart buffer vi.  The x axis is the current time.  However, the axis will continue to compress as the buffer gets full and the data becomes unreadable.  I want to control the minimum and mzximum time on the x axis so that it constantly updates.  I have successfully done this when I use a difference in the current time and the start time using the property nodes under xscale-range-xminimum and xscale-range-xmaximum, however these property nodes only take a double as an input.
Any ideas?
(3,399 Views)
Any ideas?
Sounds like you know how the scale needs to be manipulated. Are data types the problem? If so, you can convert timestamps to DBL:
(3,368 Views)
When I feed a double into the property node the plot scale does not behae properly. It seems like this might be because I am wanting time on the x axis scale and I am feeding in a double.
(3,363 Views)
What exactly is the scale doing, and what do you expect it to do?
(3,356 Views)
