XY-Graph Time&Date format
I have a question regarding the XY-graph:
LabView allows me to format the X-scale to different numeric formats
(Decimal, Hexadecimal, Time & Date ...) by using the "Formatting Dialog Box"
.. It is also possible to change the X-scale format during the runtime by
using the property-nodes.
But especially the Time&Date format is always fix (long term M/D/Y HH:MM:SS)
while changing during runtime.
How can I customize the Time&Date format (only HH:MM:SS) of the X-scale
during runtime?
Thanks for help!
Mareike
(2,986 Views)
Hi Mareike,
Are you wiring in a 6 to the Format property? 6 is for relative time which is what you need.
You can additionally wire a 0 to Precision to make sure you don't see any milliseconds.
Hope this helps,
Khalid
(2,986 Views)
Take a look at Variable-Time Chart XY.vi in LabVIEW example, it contains some ideas that you can apply.
(2,986 Views)
