XY Graph Tracing
Hi all,
I had a program where I read out an ascii tab-delimited, two-colum file.  The first column contains X values.  The second column contains Y values. I would like to construct a program which traces out this XY plot and outputs the last value.  Everything is working like a charm except the graph is totally blank, and I can't understand why. Any help is appreciated.
Thanks in advance,
NSG
(5,144 Views)
You did not include a datafile.
How many points are there?
Maybe you want a plot that shows points instead of connecting lines? (a line needs at least two points to show!)
What should happen when you run out of points?
(5,138 Views)
  • Right-click on the Array Subset function, choose Help, and read the Help Message.
  • Don't use Express VIs, don't use Dynamic Wires
  • If you've got a 2-by-N array, you should be able to pull out X-Y pairs.  If you've got X-Y pairs, you should be able to figure out how to plot them.
  • Take the LabVIEW tutorials (upper right corner of the Forum home page) if you are just beginning.
Bob Schor
(5,134 Views)
Try something like this....
Some additional comments to your origianl code:
  • Don't convert the same string array to a DBL array with every iteration. This belongs outside the loop. (Well, the compiler will probably do the right thing by eliminating loop invariant code, but still...) 😉
  • Use the correct representations, i.e. don't mix blue and orange for the indices.
  • Don't maximise the front panel and diagram to the screeen. that's very annoying!
  • Don't use dynamic data and express VIs as has been mentioned.
(5,125 Views)
Oh cool I appreciate it.  I have attached the data.
With the plot I meant that I wanted the graph to trace it out but keep the trace, not just roll with a single point but hold onto the it as it goes through the entire voltammogram I have attached.
Thanks again.
(5,109 Views)
Accepted by topic author Sidelingscroll
Like this, maybe?
(5,094 Views)
That's great.  Here's my final program and text input file (I had to multiply the values in the second column by 10^6 to get them to display correctly, but that's ok)
(5,059 Views)
