XY Graph & Move Axes to middle
Is there a way to format an XYGraph so that the X and Y Axes are not at the left and bottom as default, but located at x=0 and y=0 (similar to a crosshair section)?  I've been unsuccessful finding a property to control this.
Paul
(3,160 Views)
Couldn't find any default settings, but if you right click on the graph and go to Advanced » Customize you can adjust the graph's appearance. Double click on the axis numbers and drag the x and y to the middle. You'll want to mess with the color settings to see the axis.
Jake H | Product Manager
(3,140 Views)
Didn't think to go the customization route.  I'll give it a whirl.
(3,114 Views)
