XY Graph & array
Hey everyone,
I am having a conceptual problem. I have an array that has 8 elements
and I want to plot them in on the same graph. I can't use a waveform
chart because it crashes on the PDA platform. If i try wiring the array
to a waveform graph it works but I only get 1 value for it being
plotted. I want to use an XY graph but I can't wire it directly because
it isn't a cluster of arrays. I am not sure how to go about plotting
this data. Thank you in advance.
(4,588 Views)
Hi GHernandez,
    The following information may help you:
    You can bundle your array as a cluster,than show it by XY Graph.
(4,567 Views)
It is quite easy, I think the help topic about Graphs and Charts is quite well done, have quick look at it 😉
There is a quick way to plot your 8 (or more.. or less) elements in an XY graph, I hope this is what you were asking for and thatit wil work on your PDA Smiley Surprised
Message Edité par TiTou le 02-23-2006 07:37 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,568 Views)
Also, search the example finder for XY Graph, and you will find an example which shows you exactly how to do this.
___________________
Try to take over the world!
(4,559 Views)
Keep your array as y axis and create another array of x axis with the corrresponding indices of each of original Y array's elements.
Now bundle both these arrays and plot
(4,548 Views)
