XY-Graph, draw Measured value with Timepstamp (e.g. -> 2,34; 12:31:12)
Hi there,
I have a proble to draw a XY plot. How is it possible to set the X-axis with the recorder timestamp ?
pls see the attachmend!
Thank you!
(3,152 Views)
I can't look at your VI, but try right clicking and selecting Properties>>Format & Precision and change to Absolute time. If you're using a chart, you will need to set the Offset and Multiplier properties in your code using a property node.
___________________
Try to take over the world!
(3,143 Views)
Hi tst,
I´m using LV7.1
I´ve attached the diagram as a JPEG.
The problem is, the timestamp ia a string. A XY-graph does not accept a string!
(3,139 Views)
You can translate a string to a timestamp by converting each element to a number and building a time cluster. The attached VI shows an example of the technique, but it's not finished and probably has some bugs. If your format is set, you can write a small piece of code to do this.
___________________
(3,134 Views)
hi!
I modified your VI a little, it works now.
Connect an array of (Time-)strings, the output is a formated timestamp.
I think this funktion should be in a standard LV lib.......!
(3,129 Views)
Couldn't agree more. Make a suggestion.
___________________
(3,120 Views)
