XY Graph - minor grid style
Hi, is there a way to change the minor grid style on an XY graph?  Like making it a dotted or dashed line?  Thanks!
(6,018 Views)
Hi akalei,
the minor grid line has the same properties as the major grid line - you may change it's color...
(6,017 Views)
Hi akalei,
You can change the minor grid color either by right clicking on the graph, selecting Properties, and going to the Scales tab, or programmatically through a property node like in the screenshot I have attached.
Best,
Dan N
(5,996 Views)
It would be really cool to be able to change the minor grids to dashed lines.
(5,236 Views)
Hi anonamouse,
when you want to have a certain feature included in LabVIEW you should post your idea in the LabVIEW Idea Exchange!
(5,214 Views)
