XY Graph not Plotting All Recorded Data
When my program goes to plot the data that it just recorded, it does not plot all of it.  The data comes in as a 1D array containing DC voltage readings and corresponding time stamps.  I then rearrange the data into a 2D array based on how many channels I am scanning at that particular time.  Next the data is broken up by channel and by data type before I bundle the time and voltage data for each individual channel.  I then create an array of these bundles in order to plot all the data.  Unfortunately, not everything goes as planned.
But when I was trying to debug the program, I placed indicators all along the data flow and everything looked great.  It's only when I go to plot that there are problems.  The first channel is normally perfect, but then it just seems to skip out on data for other channels.  Some only have half of their data actually plotted.
Please let me know where I am going wrong or if you have an idea for another potential solution.  I am using an Agilent 34980A mainframe along with a 34925A module to get the time and voltages.
Thanks in advance,
RT
(3,316 Views)
Did you try to set to plot to synchronus display and see what happens (right-click on plot, select advanced and synchronus display)
Kudos and Accepted as Solution are welcome!
(3,306 Views)
I just tried that and there was unfortunately there wasn't any change...
Thank you for the reply! Any other ideas?
(3,290 Views)
Pretty embarrassing but all I had to do was turn off the autoscale.
Turns out that when autoscale is on, not only you can't see the data points on the graph out of range, but they don't get transferred to spreadsheet when you extract the data to excel either.
Sorry about that! Thanks again for your help
(3,279 Views)
