XY Graph properities
I want to change plot's properities in XY graph. I used Property
Node. I chosed Properities --> Plot --> Point Style, and it works, but
it works only for "Plot 0" other plots have no change. How can I
change properities for all plots?
BTW Sorry about my poor english.
Z pozdrowieniami
Szymon Klause "NightSky"
Bydgoszcz
e-mail: nightsky@box43.pl FidoNet: 2:481/75
(3,038 Views)
Szymon, you have to set the "Active Plot" property to 1, 2, 3, ... (depending on which plot) for each plot you want to change point styles.
Hope this helps
Dave
(3,038 Views)
Hi Szymon,
I've done things like that, despite I never thought to change the Point Style.
You must change the property for each plot. That is, use a for loop to make active each plot first and then change its properties. Change the active plot on each iteration of the loop (0, 1, 2,... and so on until the number of plots you have) wiring the iteration index to the "active plot property".
Maybe you don't need to use the loop, I needed it in my work, but remember: first make the plot active and then change its properties.
I hope to help.
Andres Menacho
P.D: Don't worry for your English. I have to work it too.
(3,038 Views)
There's a property called Active Plot, and I believe that you have to set this first before point styles, etc if you want to change other plots.
Mark
(3,038 Views)
