XY Graph won't Display More Than 3 Datasets
I am trying to use XY Graph to display a cluster with a timestamp and more than 3 sets of data - it works fine with 1 or 2 sets of data but not more than 3. What could be the problem?
(2,629 Views)
Having two y and one x per graph is an aberration (see also this idea and discussion). You should combine each y with it's own x. Try it.
(2,618 Views)
Accepted by topic author FanHe
(2,612 Views)
Thank you! I just read your post on Simpler XY Graph Multiplot and find it quite illuminating. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Even-Simpler-Multiplot-XY-graphs/idi-p/1393286
(2,578 Views)
