XY Graph y axes are not autoscaling when 2 sets of data
I have two Y axes on a XY graph.
Both are set to autoscaling.
The range for the first Y-axis if graphed by itself goes from 0 to 0.6
The range for the second Y-axis if graphed by itself goes from 0 to 2.6
When I combine both sets of data, the y axes are not autoscaling.
What am I doing wrong?
(1,278 Views)
Accepted by topic author psuedonym
To answer my own question
Ashish Sajwan's post in this thread https://forums.ni.com/t5/LabVIEW/multiple-y-axis-xy-graph/m-p/2643279/highlight/true#M789284 is what I needed to do.
(1,265 Views)
Yes, for each plot you need to decide what Y axis they should use (By default, both go to the first axis)
(1,247 Views)
