XY-Graph
AlSheikh,
Is the line the problem? Do you just want to see dots? What version of LabVIEW?
rulrazi
I saved my VI back to 8.0 thus; it can’t be opened in anything before this. The only thing of interest I did was convert a Decimal String to a number so it could be displayed in an XY Graph.
Charlie M. CLD
Message 11 of 17
(1,310 Views)
Hi Charlie
The problem is when I download "Untitled2.vi" and I open with my Labview its appeared:
"An error occured loading VI 'Untitled2.vi'. Labview load error code 9: VI version (8.0) is newer than Labview version (7.0)."
What i need to do to open this VI file with my labview?. Fyi, right now i'm using Labview 7.0 express.
Rgds
rulrazi
Message 12 of 17
(1,299 Views)
You need to upgrade Labview!  Version 7.0 is quite a few years old.Smiley Wink
Most versions of Labview can only save back to 1 previous version.  (LV 8.5 can save back 2 versions to LV 8.0).  You can't open a newer VI in an older version.  Thus why you can't open an 8.0 file in 7.0.
If someone has LV 8.0, they can save it back to 7.1.  Then if they have 7.1, they can save back to 7.0.
Easiest is to recreate from the attached screenshot.
Message Edited by Ravens Fan on 12-12-2007 11:18 PM
Message 13 of 17
(1,296 Views)
Thanks raven. Its works with my Labiew after i recreated. Only the version it makes i unable to open this file.
Can u help me, that i need to build 'dummy data' like some database, and display to graph? The 'dummy data' have 2 input which x and y with random value. Then this random value will be display at the graph. I'm glad if u can help me or anyone in this thread. I think the random value can create by table. Need some help and guideline from you and others.
Thanks & Regards
rulrazi
Message 14 of 17
(1,286 Views)
In the numeric pallette is a random number function.  It creates a random number between 0 and 1.  You can use math to scale and/or offset that number.  So if you want a random number between 1 and 10 let's say, multiply by 9 and add 1.  Between 0 and 10, just multiply by 10.  Use rounding functions if you want integers.  Use a group of these for each X and Y.
Message 15 of 17
(1,277 Views)
Hi All,
I use 8.5 version.
The program work fine, but :
X scale from 0 to 10
Y scale from 0 to 20
 when I enter value of X and Y ( e.g  x=4, y=6)  it exists on the graph  OK
but,  if I enter (e.g x=2.56, y=6.87) nothing happen.
I idetify tah X, Y floating .
so, the program work with integer just!!
Any help???
Message 16 of 17
(1,260 Views)
Please attach your program.
Message 17 of 17
(1,258 Views)
