XY Graphs
I am trying to design a circuit that will show how the voltage falls across a resistor in a simple CR circuit when excited by a step function.
The parameters are:
Number of points for the Vr plot, default 100.
Final time T1 in milliseconds, default 50 (ms).
resistor value, default 500 ohms.
capacitor value, default 20 microfarads.
step input function, default 10 volts.
Any help or prompts would be appreciated!
kadeel
(2,936 Views)
This appears to be the same question you asked here and here and here.
In the ones where people actually took the time (this is a board made up of volunteers) to actually try to ask you a follow-up question or give you information you never followed up. Instead you just created a new thread. Why should we bother answering this one if you're just going to continue ignoring us, in the hopes that someone gives you a ready-made VI, which appears to be what you're really fishing for.
(2,919 Views)
