XY Multiplot Graph not showing all plots
Hello all,
I have an XY Multiplot Graph in my VI. It takes in a cluster of three arrays. The problem is, when the data is plotted, only the first two plots show up, though. I attached a VI with the problem code. What am I doing wrong?
(1,316 Views)
You aren't building your clusters/arrays in a way that will show 3 plots.
You are effectively plotting the 2nd array Y versus the 1st array as X.  And it ignores the extra data point.
Perhaps you want to show a waveform graph instead of an XY graph?
Look at the detailed help for both XY graphs and Waveform graphs.  Each have several different ways of building the data sets.
(1,295 Views)
