XY Plot
The original VI was created with Labview 7.1 now I have upgraded to Labview 8. I experienced a problem in 7.1 that I would like to know if there is an easy fix for in 8.0.  The xy plot that is created using buffer (displacement vs load) clears when I have completed a test. Is there anyway to keep the xy plot displayed until the next test is run. The data is being collected continuously but is only stored when a trigger value from the machine is reached.
(3,620 Views)
An XY graph does not clear between test unless you program it this way. Please attach a simple example of your VI.
Message Edited by altenbach on 01-24-2006 12:00 PM
(3,618 Views)
Attached is the working VI
(3,581 Views)
