XY chart data adquisition
I am adquiring data in real time, I process the data and I send the information to an xy graph, I want that every loop the next data does not erase the previous.
I attached two images where I show the xy graph, my idea is that every loop the new data will be plot in the same graph without delete the previous data.
(2,973 Views)
It would be more interesting if you would show the diagram.
If you are using the "build xy graph" express VI, simply configure it to retain data between calls.
(2,965 Views)
Yes, I know that it is not so interesting but I am a new programmer. You are right I am using build xy vi and you resolve my problem.
thanks for your help.
(2,945 Views)
