XY chart with plot as f(z)
My colleague is making wonderfull XY charts and she can color the plot itself as a function of a third parameter.
XY chart with f(z) plot
Is there a way under Labview to do the same??
Thank you for answers
Julien
(2,726 Views)
Julien,
the LV graphs only support a single color per plot.
You can split up your plot into several and use a XY graph to place each plot in the correct "slot" with it's appropriate color. But looking at your attached image, this will be quite cumbersome for your graph.....
Norbert
Norbert
Expert: Geometry
(2,712 Views)
Hi Mr_J,
                       See may be you cant create exactly same chart but you can make not less than that also.
Something like this
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,705 Views)
Hi Julien,
there is no direct way to do it, but here is an example how to acchieve it anyway:
Multicolor Plot
I hope this helps,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,695 Views)
Thank you for your answers,
I will try your solution RMathews but will use simple XY for everyday working and keep to send the data to my colleague .
Julien
(2,666 Views)
