XY graph (1D array) unbundle by name (cluster)
I post again,as i am new to labview and am doing my thesis in the same.  I have a step response graph (which is a 1 D array with a cluster of 2 elements- XY graph ) generated from a state space equation. I am trying to see the 3 ouputs (y0, y1, y2) for 3 inputs (u0, u1, u2). I have 2 problems.
1. I wish to see only 3 outputs (y0, y1, y2). Hence am trying to add the elements for array y0 from the arrays u0, u1 and u2 with their respective elements . Similarly for y1 and y2. How could i do this?
2. I am trying unbundle by name the cluster of 2 elements (from the graph) but i get only time (which is the x-plot) it does not show the y plot (which is amplitude)
I also attach the jpeg image.
Thanking you again
(4,051 Views)
Did you try to change one of the unbundle elements (you can get a hand cursor when you put the cursor over the name, click and choose the desired value)?  Are you sure there are 2 elements in your cluster?  Without an actual VI, it is hard to debug this.
(4,048 Views)
Thank you for the quick reply. The vi. size exceeds the allowable attachable size, hence i  am sending again the JPEG of the entire vi.
(4,041 Views)
