XY graph - Get X values of two cursors ?
am plotting graph on a XY graph. There is only one plot.
I want to allow the user to select two points in the graphs using two cursors I have names "min" and "max".
Once two cursors are properly placed by the user, after he clicks a button, I need to obtain the two 'x' values of the cursors.
How would I do this.
Is it also possible to restrict the two cursors such that the "min" cursor does not overtake the "max" cursor?.
(3,223 Views)
Accepted by topic author Chathuri
Use Property Node to extract the X value of the coursor.
First set the "Active Cursor" in the property node and then  "Cursor.PosX"
All the Best.
(3,220 Views)
