XY graph : Plot point by point
Hi Andrew,
I think waht I am tryin to do is slightly different to what you have done. Let me explain more. Let;s say I have an array 'A'  which has 50 numbers. Number by number I want to check if the values fall between let's say between 0-10, 10-20, 20-30 and so on. If it falls between 0 -10 I want to plot that value in 'RED' color, if the values falls between 10-20 I want to plot that point in "blue" color and so on.
This is impossible for me to figure out.
I hope you understood what I just said 🙂
It would be of great help if you could help me with this.
Chathuri
Message 11 of 15
(1,831 Views)
Accepted by topic author Chathuri
Hi Cathuri,
I have attached a new VI. In this VI, there is an array of 6 elements, numbers one to six. The program will then sort out the numbers into separate arrays; one with numbers 5 & 6, the other with 3 & 4. Once this has been done, it will remove padding zeros and plot the data sets on two different plots in the X Y Graph. I haven't added the logic for 1 & 2 since it is the same as the 2 previous pieces of logic. My suggestion to you would be to pass through your x values in a simlar manner to the Y values.
I hope this makes sense, please let me know how you get on.
Andrew McLennan
Message 12 of 15
(1,809 Views)
Hey thanks alot for the solution. I think this is just fine. 🙂
Message 13 of 15
(1,795 Views)
Cani have this VI for labview 8.2 please..
Labview 8.2
Learner
Message 14 of 15
(1,772 Views)
Hi All,
Attached is 8.2 version of the VI.
thanks,
Andrew McLennan
Message 15 of 15
(1,758 Views)
