XY graph: getting error while writing x axis from csv file
Hi there,
I have attached the code below in which when I am changing property of graph for X axis to absolute time: HH:MM:SS I am getting error: "LabVIEW: (Hex 0x1) An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @." When running my code first time before any change i.e. with double representation of timestamp i am not getting any error.
(1,454 Views)
Accepted by topic author doc_d
Hi d,
Because your format string does not fit to the data in that CSV file!
You are looking for "H:M:S", but the file only contains "H:M".
(Maybe you should implement some error handling in your VI?)
Btw. to understand your code it would really help when you cleanup before uploading. LabVIEW has an AutoCleanup feature…
(1,446 Views)
Thank you for the solution. It's working now, I just made this silly mistake😅. Cleaned up the diagram and added error handling like you suggested.
(1,389 Views)
