XY graph memory length
How do you set depth of XY Graph? After a while I cannot scroll to the first measurement. On Chart you can change "Chart History Length" but I didn't find something like it for XY Graph.
(5,546 Views)
An  xy graph will display all of the data passed to it and does not have a history setting. Are you sure it's a normal xy graph and not the xy chart from the examples?
(5,542 Views)
It's "Build XY Graph" from Express vi pallet. After a while first points are gone, and looks like there is no way to control number of points on the plot.
I put example in attachment.
(5,536 Views)
Well, I have never use the express VIs and probably never will. Using the normal xy graph is not that hard.
Message Edited by Dennis Knutson on 02-04-2009 02:38 PM
(5,528 Views)
I wander what will happen with this graph if keeps just adding points. If there is no way to set buffer size it might slow down the whole system.
(5,502 Views)
Of course it will slowdown. It will depend on how long your run it. Look at the shipping example called XY Chart if you want to use a buffer to limit the size. That contradicts your orignal problem of not being able to scroll back to the beginning of the data.
(5,499 Views)
