XY graph - portion of plot disappears and reappears
I am having a problem with an XY graph which is displaying data that are continuously collected from 3 AI channels. Every time the graph updates whole portions of the plots disappear and then reappear during subsequent updates. The actual data are still there (can be probed with a cursor) but the graph display doesn't show it. I attached two images showing the problem. In 1.bmp all three plots have the exact same # of data points but the green and red plots are not displaying toward the end. In 2.bmp all plots have several areas that have blanked out.
So far I have tried:
Changing priority in task manager to high: did not help
Slowing down graph updates: did not help. the problem definitely follows the graph update frequency though. If the graph updates every .5 seconds the problem only occurs every .5 seconds.
Turning on antialiasing: fixed the problem but computer slows to a crawl. (integrated graphics)
Switching computers : fixed the problem.
Minimizing and Maximizing the window : did not help.
Computer specs where problem is occuring:
I3 2100 ~3ghz
3gb ram
integrated graphics
windows xp
labview runtime 2012
Next I will try a computer with dedicated graphics card. Just wondering if anyone else has experienced this problem. Thanks!
(2,710 Views)
how much points does your XY graph have ?
Best Regards,
V-F
(2,684 Views)
Around 3600. The number of points in the graph doesn't seem to have an impact though. The problem occurs even when the graph has just started plotting.
(2,663 Views)
Update:
With a new computer that has a dedicated graphics card the problem has gone away.
New computer specs:
Core 2 Duo ~2ghz
2gb ram
Radeon x1600
Windows XP
LabView 2012
Still wondering why the other computer has a problem though; in most respects it's faster. Maybe something to do with graphics drivers?
(2,659 Views)
