XY graph position changes when legend position is set!.
Hello All.
Try the example in attachment. When I change the position of the graph legend, the position of the total graph is changed!!! Or maybe I am doing something wrong?
Pawel
(2,833 Views)
Hi Pawell,
the Position property returns the top left coordinates of the front panel object including its related objects.
If you place the legend above the graph, the Y coordinates refers to the upper position of the legend box rectangle; this is why if you move the legend up and down, the graph position value changes although you are not moving the plot area.
Ask if I haven't been clear enough.
Alberto
(2,833 Views)
Hello Alberto
Yes, of course, thank you very much.
regards
Pawel
(2,833 Views)
