XY graph refresh rate is too slow ?
I'm trying to realize UI function and that will be in one xy graph showed.wenn i turn tracking mode (Highlight Execution&Retain Wire Values) then program runing throught the loops, measured the current and voltage and showed that in graph for every individual measurement (Value) in realtime.Ofcourse it is too slow and i turn off that.Then i started the program and i get one measurement  point with straight line.What can i do ?
(3,030 Views)
That's a bit hard to tell without knowing your program. Why don't you post your VI for us to take a look at it?
Without seeing the program, my best guess would be no timing in the loop.
Remember Cunningham's Law
(2,997 Views)
