XY graph two y labels
Hi
I am trying to have an XY plot with a y scale on the left and on the
right and want 2 labels for them. I use property nodes to
programmatically set the label by writing to the the variable
Yscale.NameLbl.Text but this changes both labels. Does anyone know if
it is possible to change them independently?
Julian
(3,540 Views)
Hi Julian,
you have to set the active scale first. You can use the same property node for it, but the selection has to be above the label change.
Mike
(3,535 Views)
A simple forum search returned this
(3,533 Views)
> Thanks Julian
This group is pretty much dead. Try the forums.ni.com
To answer your question, I believe you have to set the
Active YScale first, then you can change the second label.
Property Node/Properties=Active Yscale (ActYScl) change to write
Property Node/Properties=Yscale.NameLbt.Txt, change to write.
(3,515 Views)
> Thanks Julian
(3,515 Views)
> > Thanks Julian
Knock of the comments about 'this group is pretty much dead'. This
question was mirrored from forums.ni.com and you should realize that.
You are just posting noise.
(3,505 Views)
