XY graph using formula node
Delete the multiply and change N to 100. Then you have 0 <= i < 100 and 100 <= x < 200.
Lynn
Message 11 of 14
(1,319 Views)
At last i got it...thank u so much...to every one helping me....i attached the file...what i did..thanks again..:)
Message 12 of 14
(1,316 Views)
Can I know why the attached file..is not giving the exact values in graph...please reply
Message 13 of 14
(1,298 Views)
Please explain what you think it should be giving.
It appears to me that is is doing exactly what you programmed it to do. You send it an array of two points, both with the same Y value and it plots a horizontal line.
Lynn
Message 14 of 14
(1,291 Views)
