XY graph with N axes and translate it into a picture
Hello - The VI has two windows diagrams (lower, narrow) is possible to unite them in one picture? - The VI (top left window graphics) have a common axis, but its hard to see the first graph "PLOT0" because he has little value compared with the values ​​of graphics "PLOT1", to avoid this problem, adding even more axis "X and Y '(top right graph window), now both graphs are visible, but they overlap each other, how to spread these graphs relative to each other. (In the diagram where one axis is obtained by adding a factor to make a Slider and Slider1), and the graph with 2 separate axes do not get how to be? - Is it possible to programmatically make up the axes of the "Duplicate Scale"? Thank you.
(2,438 Views)
You can move the secondary axes to the other side of the graph by right clicking on it and selecting "Swap Sides."
I don't understand this question. Do you want to programmatically set the Max and Min of the axis? Please clarify the question.
Nathan S.
(2,407 Views)
