XY graph
1) May I know what should I do in order to have my graph move at the same time as my level increase/decrease?
 the problem I facing now is the graph drop immediately to number i selected.
Message 1 of 9
(4,643 Views)
Could you provide a bit more detail on the issue that you are having with your current VI? Have you tried moving Wait out of the for-loop?
Andy Chang
Message 2 of 9
(4,624 Views)
The data for the graph doesn't really make any sense. You're always plotting the same value. What are you trying to graph? Are you trying to create a "real-time" XY graph? If so, take a look at the examples that ship with LabVIEW. There's one called "Real-Time Chart". Or, are you trying to create an XY chart? If so, again, take a look at the examples that ship with LabVIEW. There's one called "XY Chart".
Message 3 of 9
(4,620 Views)
Not capable of following simple instructions.
Message 4 of 9
(4,615 Views)
Thanks, Dennis, for pointing out this is an off-shoot of that thread.
Message 5 of 9
(4,611 Views)
Hi Dennis,
I'm really trying alot ways to make the system work the way I want. But Labview is really kind of difficult for me. I really appreciate any kind souls out there could help me. the graph look very wrong when I select level.
What I actually really to do is to create a lift system monitoring which I could control the velocity of the lift and a graph displaying the timing that took for each level.
I tried to ask my friend but no one really know much about labVIEW and i'm running out of times as due date is out soon.
Please kindly advise on how could i make this work properly. Thank you so much.
Message 6 of 9
(4,595 Views)
Hi Andy,
I had tried moving the wait out of the for loop. Example, if I select level 5, the LED 1 will light up first, then follow by LED 5. LED 2, 3, 4 will bypass.
I need a real time chart that timing will follow the flow of each level travel.
I had also tried adding shift register and moving the whole XY graph functions into for loop. it still doesn't work the way I want.
Message 7 of 9
(4,583 Views)
May I know how could I add in a weight sensor function into my lift monitoring system?
Really appreciate if any kind souls can help me...
Thank amillion in advance..
Message 8 of 9
(4,539 Views)
If you use straingage load cell, couple of DAQ is available: http://sine.ni.com/np/app/main/p/ap/daq/lang/en/pg/1/ps/20/sn/n17:daq,n36:13
Then, use DAQ asssitant to acquire weight.
Message 9 of 9
(4,490 Views)
