XY graphs
Hi friends,
 I want that signals which displayed in two different XY graphs is combined in a XY graph. for this, what can I do?
(3,146 Views)
You can use the build array function to combine two scalar XY graph data, then graph both signals.  If you open the context help and hover over a new XY graph terminal you'll see that it tells you how to graph multiple signals.
(3,140 Views)
thanks
(3,134 Views)
One of the parts of using an XY graph that many people find confusing is that the data can be defined is several ways. Regardless of the representation you use, you can put multiple plots on the same graph by combining them into an array -- as brother Hoovahh said.
Note also that these plots have a z order. In other word the plot at element 0 will be on the bottom, element will appear on top of the element 1 plot and so on.
Also the help screen he referenced also has a link in it to a good demo.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,129 Views)
