XY plot on table grid, highlight cells?
Hello,  I am new to LabView programming,  I have searched for any information but have come up short so far.
I am working on a VI in which I am connected to the serial interface of a microcontroller,  one that is controlling automotive fuel injection.  I am using visa controls and the application is finished to a point that I have the data in arrays and in certain streams that I need.
I am wondering if there is a way to input an array to a table or a graph for the X, Y axis and the Z axis.  After that,  having a real time value for both the X,Y , as an input to trace or plot its location on the table/graph (in reference to the XY axis)?
Somehow possible to create a table of cells of which could be highlighted as a plot indicator?  Or possibly a 3d control?  I have looked through a few with some ideas,  all seem to be analyzing the data differently that I need to.
I would appreciate any tips.
Thanks!
(3,589 Views)
Have you looked at Intensity charts in LabVIEW? If I am understanding you correctly, it looks exactly like what you need.
As for highlighting cells in a table as a plot indicator, you can use the active cell and cell background color properties to change the color of a cell. I have made a crude example for the same.
Hope this helps,
Ankita
(3,576 Views)
Thanks Antika!,  thats pretty much what I was after in a highlighted cell table.
I got a bit more curious and looked in the property nodes for any way that I could also input a value to the active cell (with or without highlight, color fill),  but I could not seem to find what I was after.  Is their a simple way to do this with a property node or am I off base?.
I had set up an XY graph with cursor controls earlier,  Im going to check out the intensity charts, thanks for the tip!
(3,564 Views)
Hi Devious,
If you decide to go the 3-d route, this link
http://forums.ni.com/ni/board/message?board.id=170&message.id=158594#M158594
contains other links that demonstrates some cool options.
Ben
Message Edited by Ben on 01-05-2006 06:05 PM
(3,552 Views)
Check out the Set Cell Value method. The X and Y index values that you use with this method can be converted to a cluster for choosing the active cell.
Hope this helps,
Ankita
(3,533 Views)
