XYGraph Secondary Axis
Very simply problem: I have a few curves on a single XYGraph. How can I make the Y-axis for one of the curves a secondary axis?
See the attached VI.
I did give it a try, but I get Invalid Property Value error. My unerstanding is Plot.YScaleIdx = 0 for primary Y-axis and 1 for secondary Y-axis. Is this not the case?
(2,838 Views)
Accepted by topic author murchak
You need to duplicate the scale before you can write to it.
I did it manually, then your code worked without error.  I don't know if there is a programmatic way to duplicate the scale.
EDIT:  According to this http://forums.ni.com/t5/LabVIEW/how-to-show-duplicate-scale-programatically-on-chart-indicator/m-p/1... you can not programmatically create the scale.
(2,824 Views)
