XYGraph export image, no color on the Y scale
I want to export the XY Graph to the image of the emf, using the Export node, but the Y scale is not color-differentiated, it is all black.
Is there any way to make the Y scale in the imported image also have a different color?
(1,206 Views)
Hi hy,
don't export to a file, but get the image:
You can then export the 2D picture to one of the supported image formats using the PictureFile functions…
(1,169 Views)
Hi GerdW,
This is of course possible, but I need to export vector image, in order not to be distorted.
(1,159 Views)
Hi hy,
When that's your requirement then you need to live with the image you get.
The export method seems to export just black/white scales…
(1,153 Views)
