Xcontrols and Data Binding
Hi
Is it possible to bind specific controls in a Xcontrol to e.g. a Shared Variable programmatically? I have tried using the Bind to Network Path method, but I only manage to bind the Xcontrol it self. When I try to bind a controller inside the Xcontrol, nothing happens. I have tried applying the method in both Init.vi and under Exec State Change in Facade.vi.
Regards gelmin
Message Edited by gelmin on 03-06-2007 11:46 AM
(3,722 Views)
Dear Gelmin,
Thanks for your request. I make some investigation a find an helpful example that could help you in your development.
Best regards
Nick_CH
(3,684 Views)
Hi Nick_CH.
Thank you for your reply. I have actually looked at this example, but unfortunately it doesn't help me as I want to bind the control inside the Xcontrol, and not the Xcontrol it self. The reason why I'm looking in to this is that I need a way to dynamically both read and write several shared variables inside a Xcontrol. With data binding of controls I could sort of do something like this.
The most obvious way to achieve this though is to use Datasocket, but I'm afraid this will affect performance as I will have a lot of variables to manage. I have read somewhere that one should only use Datasocket when dealing with less than 30 variables or so. Are there some clever way to dynamically read/write Shared Variables whit out loss of performance?
Best regards gelmin
(3,667 Views)
