Xilinx CIC 4.0 Kintex 7 target (2015 and 2018)
I have some problems with porting some code from Virtex 5 to Kintex 7 (LV 2015).
When trying to implement a CIC filter analog to how we have it on a Virtex 5 target, it seems that the port widths / datatypes defined in the Xilinx portion of the configuration is not reflected in the LV portion of the configuration.  Regardless of my settings, input is defined as 24 bit and output 32 bit with a 16 bit value for channel index.
I've tested also in LV 2018 and see the same thing there.
Is there anything about this IPCore in specific I should be aware of or do I need to implement the CIC filter myself?
(2,648 Views)
So in these two images, normally the bit widths of the data configured in the CIC Compiler 4.0 dialog (first image) and those later in the LabVIEW dialog (second image) match but here they do not.
2019-03-11 16_27_38-Re-customize IP.png2019-03-11 16_26_29-Xilinx CIC Compiler v4.0 Node Properties (Page 4 of 4).png
I've converted 15 different IPCores from Virtex 5 to Kintex 7 in LabVIEW 2015 and this is the only one I've encountered so far which behaves like that.
(2,620 Views)
For clarity, in the lower image:
FXP<+,24,24> should be only 20 bits wide
FXP<+,32,32> should be 28 bits wide and
FXP<+,16,16> should be 2 bits wide.
(2,611 Views)
