10-03-2017 12:11 PM
Hi;
I am working on a project which i need to use Xilinx FPGA DDS Compiler, but i don't know why I am encountering with the
following error. i am using LabView 2015, while Xilinx 10.1, xilinx 14.7 compiler and Xilinx 14.4 Vivado tools are installed as add-on.
"Error 7 occurred at Open/Create/Replace File in MD5Checksum File.vi->niFpgaXIPINIsFuse2Needed.vi->niFpgaXIPINConfPage1.vi
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
C:\NIFPGA\iptemp\xipin8EE3814B93AE4DDF942A4AA8EE9C6515\DDS_Compiler_F6E9D9D81C784E0EAFE277F741BA8D45.vhd"
any help would be appreciated,
best regards.
10-03-2017 01:25 PM
You cannot use File-VIs within an FPGA-VI, there's no direct access from the FPGA chip to your HDD device.
Regards, Jens
10-04-2017 03:07 AM
thank you for your reply.
but this error occur while Xilinx compiler tries to compile a DDS compiler on an FPGA target VI.
I have found the right path, but as you can see it is kind of a temporary Xilinx compilation file.
10-04-2017
03:15 PM
- last edited on
09-30-2026
04:01 PM
by
Content Cleaner
I found a couple KnowledgeBase articles that might give some explanation
http://digital.ni.com/public.nsf/allkb/66FE4C3781B66A1886257961004223FD
http://digital.ni.com/public.nsf/allkb/617AACACD3F802F786257D0E0055C600
