Xilinx Options not available to me
I came across this page:
ftp://ftp.ni.com/pub/devzone/pdf/tut_9381.pdf
and I am interested in playing with the Xilinx compiler options. However, when I right click on the FPGA target in my LabVIEW project and go to "Properties" I do not have "Xilinx Options" as a category. I have included a picture of what shows up. Is there something I need do in order to have these options appear? I am using LabVIEW 8.6.1 with RT and FPGA Modules of the same version. Thank you.
(3,012 Views)
I see it on my 2009 version. I checked the release notes and it was added in LabVIEW 2009.
(2,995 Views)
Hi Brian,
Ernie's right, see page 5 of the LabVIEW FPGA Module Release and Upgrade Notes.  Also, see the LabVIEW 2009 FPGA Module Help for a detailed explanation of the options available to you with this new feature.
(2,951 Views)
I don't see the Xilinx Options either & I'm using LV 2011.  However, the availability of that option appears to be target specific, so I assume the PXIe-7962R doesn't support those options.Smiley Sad
(2,684 Views)
Unfortunately, the Xilinx options aren't available for a user to make changes for any FlexRIO target.
Austin S.
Academic Field Engineer
(2,658 Views)
