Xilinx platform cable
Hello.
I bought Xilinx Platform cable. I installed flexrio driver 17.0 and ise xilinx compilation tools 14.7. But when I insert it in controller 8133, it doesn't correct define in system. Wrote that *.inf file is incorrect. Is anyone faced such a problem?
(2,846 Views)
Glancing at the datasheet for that cable I see no glaring HW incompatibilities between it and the PXIe-8133 controller so my guess is that this is a SW problem. This may be a good question to direct towards Xilinx in addition to here if you haven't already as I think this falls more on the Xilinx side.
A shot in the dark for what might be happening is that you installed the Xilinx ISE Compilation tools from the NI website rather than the entire ISE Design Suite from Xilinx and that the hardware drivers for this cable are included with the Design Suite.
Thanks!
Alex W.
(2,792 Views)
