Ximea xiQ camera, Timeout Error.
Hello Team NI,
I am using a lab view program for controlling a microscope, including 3 cameras. 2 from Ximea (Ximea xiQ) and 1 from ANDOR (Andor zyla sCMOS).
Recently I used one of the Ximea cameras with python codes, using xiAPI from Ximea. The operating mode for camera was switched from USB3 Vision to Ximea API using Ximea camera control panel. Everything worked fine as intended.
But later when I used my labview program, this particular camera is throwing some error.
I checked with NI-MAX and found that this camera is showing the timeout error 0xBFF6901B. The mode was switched back to USB3 Vision using Ximea control panel, also NI IMAQ-dx driver was selected from the NI-MAX. These didn't solve the issue.
Is there a way so that I can get rid of this error and get my system back running.
Regards
Dijo
(1,948 Views)
Hello Dijo98
Check this Article to solve this issue.
Regards)
_________________________________________
The best way to thank is Kudos / mark as a solution
(1,863 Views)
