Xnet CAN
Hallo,
i prepared a database with message 1 and message 2 using XNET database editor.
Message 1 Input:
  Tnumber u8
  range 0..200m Resolution 0.1
  velocity -200 ... +200 Triggering 0.1
Message 2 Output:
Dnumber u8
velocity -200 ... +200km/s Resolution 0.1
Now message 1 is to be sent from CAN 1 and CAN 2. Here it should be possible to send 3 targets with different distance . Message 2 is now to be sent from CAN 2 to CAN 1. This regularly sends the values for target 1, 2 and 3, taking values from the received message 1 and adding random numbers in the range of +- 1% of the range.
i did a sample vi which is able to send the message 1 from CAN 1 to CAN 2. then modify the data by adding random numbers to range.and i cannot send the message 2 from CAN 2 to CAN1.
I have attached the vi here.I am using single XY mode.
How to do the same with frame mode and single point?
Please guide me.Thank you in advance
(1,805 Views)
You cannot use XNET Read on an output session. If you want to read and write on a single interface, you must use two different sessions.
See shipping examples at Help >> Find Examples >> Hardware Input and Output >> CAN >> NI-XNET >> Intro to Sessions >> Multiple Sessions
https://tmesystems.net/
(1,794 Views)
would you give me some more information with rrespect signal XY session mode and Vi attacehd?
Sorry as i am new to this Xnet, it would be great if you can give me some deatiled info and suggestions
Thank you in advance.
(1,778 Views)
See Session Modes for detailed explanation.
(1,753 Views)
