Xor of array elements
Dose anyone know how to get Exclusive Or (Xor) on array of U8 elements
in LabVIEW?
Avivit
avivit@helicontech.co.il
(4,831 Views)
Avivit Noiman wrote:
> Hello,
> in LabVIEW?
> Avivit
Create a for loop with a shift register. Initialize the shift to zero.
Feed the array in (let it autoindex) use the XOR function to
xor the shift with the U8 value, stuff into the shift register.
This will XOR all the values of the array together, and give a single value
I think this is what you want.
Kevin Kent
(4,831 Views)
