Xy graph chart with starting value
Im currently working on a Dyno daq system for a brake type Dyno.
Got most of my functions working but having problems with displaying my sweep in a graph.
Is there a way to have a xy graph act like a chart. And not starting to plot before say 1000rpm?
With rpm on one axis and force on the other. And maybe a ekstra plot with calculated hp.
Sorry for my english (Norwegian)
-Sigge
Message 1 of 9
(5,391 Views)
You can certainty program an xy graph to look like a chart, but you have to maintain the graph data in a shift register and do the data management yourself.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(5,377 Views)
do you means some thing like this vi
try this and tell if it is what you want
Message 3 of 9
(5,359 Views)
Hi Probotech,
Simple answer: switch off x axis autoscaling and set a minimum x value of 1000: the XY graph will "start" to plot at x=1000…
Message 4 of 9
(5,355 Views)
Hi.
My version of labview is to old to open that .vi 😞
Message 5 of 9
(5,328 Views)
Hi Robotech,
Do you mind to tell us your LabVIEW version?
Message 6 of 9
(5,319 Views)
i got version 11.
Message 7 of 9
(5,314 Views)
Accepted by topic author Probotech
Message 8 of 9
(5,280 Views)
That will do the trick.
Just some small changes.
Thanks 😄
Message 9 of 9
(5,269 Views)
