06-24-2009 05:08 PM
I have 4 plots can get 2 Y scales but can't get them to scale seperatley example: x time = same, y1=o-60, y2=0.5 Plot 1 is for y1 and Plot 2,3,4 are for y2 can someone help
06-24-2009 09:50 PM
If you are trying to fix the y-scales for your plots, do the following:
At run-time, you will have to access properties of the graph to modify scales.
-cb
06-24-2009 10:29 PM
I think the op is trying to assign a plot to an axis.
When you created a duplicate axis, you have to select which axis the plot will use. You can click on the plot legend and then click the x or y (which ever you have a multiple axis for) and select the scale. You can do the same thing from the properties>Plots window.
06-25-2009 09:40 AM
06-25-2009 09:48 AM
06-26-2009
12:50 PM
- last edited on
09-10-2026
09:07 AM
by
Content Cleaner
Hi pranft,
Are you trying to plot 4 data sets on the same graph with two different y-axis?
Kristen H.
