Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Y axis position
Y axis position
Gilles Kern
Member
05-24-2004
06:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi all,
how can I change the Y axis position in a multiple Y axis graph?
Thanks, Gilles
0
Kudos
Message
1
of 2
(2,944 Views)
Reply
Re: Y axis position
Oleg
Active Participant
05-24-2004
09:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
if you want to show Y scale at the right side of your graph instead of its ordinary position at the left you must do the following things:
Right click on the title of the scale and select "swap sides" option from pop-up menu.
Good luck.
Oleg Chutko.
0
Kudos
Message
2
of 2
(2,944 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
